Engine ECU codes
Hello guys,
After a ecu remap to disable the egr, water got inside and the ecu is gone. Im trying to find an ecu now that comes with the security box, keys and everything to avoid the hassle dealing with reprogramming etc.
I have a really interesting question, if anyone knows. The ecu code, does it have to match all numbers and letters? ive seen tens of ecu with the same number, for the same engine but with just the last 2 letters being different.
so my ecu code is 03L906023LR, but i found many ecus for sale with the same number but ending in DM, LP, LL and some sellers advertising the number without the last 2 letters.
Does anyone knows if they match my engine if the last 2 letters are not the same?
I'm sure that you will also need to change the dash cluster as well as the engine ecu and the key as the immobiliser is built in to the dash cluster. What engine do you have?
Have you explored the possibility of having your ecu repaired which would save the need for re-programming?
