Aftermarket front camber bolts VRS MK2?
As above is there any options available? Can't find anything for the Octavia Mk2 VRS from the likes of Eibach or powerflex etc. Does the VRS share the same struts with anything else?
Only thing i can find is powerflex camber adjustable wishbones buses but thats just to much of a faff to fit without a decent press.
Wow this place really is a fountain of knowledge.
£12 for a membership as well, lol!
  • Sponsor
The front dampers (item 8) fit into a tubular section of the wheel bearing housing (item 12), clamped against vertical movement by a single bolt, see diagram here if you haven't looked at your car:
https://skoda.7zap.com/en/cz/octavia/oct/2007-419/4/411-411000/
Where do you plan to fit these camber adjustment bolts on this arrangement?
Yes just had to look this up. No way to fit camber bolts as the design of the stut and hub wont allow this being a slot in design.
Suprised by this set up TBH being Skoda's flag ship perfomance model sharing the same set up as the rest of the vag hundrum models for this era.
Looks like ill have to purchase the Powerflex camber adjustable wishbone kit as the OE camber is far to reserved for how i want to use the car. Its poinless putting track tyres on if they're just going to roll onto the outers.
