Help with ABS fault codes
Hi,
I have Ocatavia Pre FL MY 2007
I upgraded my ABS module from 1K0 907 379 BL to 1K0 907 379 BS and getting fault codes.
This is my previous ABS details.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 133B201C092780FDC81004EC90190181350950
   Shop #: WSC 00066 123 12345
   VCID: 7DF07450E4258AAEE1-8028
And this is my current ABS details
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 133B201C092700FDC81004EC90190081A5095072
   Shop #: WSC 00046 000 00000
   VCID: 040601B487CFFB66AE-8050
1 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 162854 km
                    Time Indication: 0
                    Date: 2059.14.07
                    Time: 23:28:21
             Freeze Frame:
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 49920
                    Count: 0
                    Count: 65278
                    Count: 4096
I upgraded SW to CC, now I am getting 2 fault codes :(
Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 CC    HW: 1K0 907 379 CC
  Component and/or Version: ESP MK60EC1   H46 0175
           Software Coding: 133B201C092700FDC81004EC90190081A5095021
            Work Shop Code: WSC 00046 000 00000
                      VCID: 75E06C70DC15D2EEA9-8020
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 162858 km
                    Time Indication: 0
                    Date: 2059.14.10
                    Time: 22:44:08
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 297
                    Count: 49664
                    Count: 0
                    Count: 65535
                    Count: 0
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 162858 km
                    Time Indication: 0
                    Date: 2059.14.10
                    Time: 22:44:17
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 49664
                    Count: 0
                    Count: 65535
                    Count: 0
Tried 62,72 and 73 in last byte but same fault code.
Isnt my car compatabile with this new pump? HW of BL is 31 and HW of BS is 46.
Please help me to fix this.
Thanks.
Assuming your VCDS interface is genuine, it's probably worth posting on rosstechs forums.
Not many on here are familiar with ABS coding and fewer with the longer 20 byte coding as they were never fitted to a MK2 Octavia.
