Brocken altinater belt problems
Looking for help!!! I own a fabia 1.4 16v 100hp. 06 plate. My Altinator belt exploded everywhere the other day car come to a halt as my battery was nackerd as well. Got a new belt and battery fitted to no avail it ticks over but won't start. Opened top of cam cover and the 2 belts at top are lining up as thought maybe timing slip but there was bits off the altinator belt tangled up on it. It's a strange 1 I know.
I'd think that you would need to check that the cam<>crank belt timing is still okay, I'd guess that the small belt is protected enough as it is inside another cover.
I've heard that this is always a possibility when you leave off keeping an eye on the auxiliary drive belt as the cam belt is normally only covered by a plastic shield and you are saying that some bits of auxiliary belt did end up in that area.
Yea there were bits of auxiliary belt rap in top 2 drive belts not check the bottom! Is that the cam crank 1? And Yea the cam belts were sealed so it's a mistery how they got there?
Got the fabia plugged into cheap odm com. It came up with p0106. Absolute manifold pressure range performance.
