Removable Boot light/Torch
Folks,
The removable boot light/torch does not appear to switch on when it is removed from the holder. Works fine when placed in the boot holder but when taken out it does not switch on (yes I am pushing the button) :)
Any ideas?
Also, should a small first aid kit be supplied? I am sure i read somewhere about this being included but for the life of me I cant find where i read that.
In "handheld"mode its the 2 little LEDs on the end that light up, not the square panel it uses in "docked" mode.
I did not get a first aid kit in mine (i think you get one in mainland Europe ,but not in UK?)
Edited by gojoholo
3 hours ago, TheWildHaggis said:
Any ideas?
Have you pulled the little plastic tab out (same thing as you get in toys with batteries pre-installed)?
And no first aid kit as standard - it's an option along with the warning triangle which sits in the recess below the boot lip.
IIH, IKEA do a fairly comprehensive First Aid Kit for a reasonable price. And a 1kg Dry Powder Extinguisher, if you're so inclined.
If the rear side recesses in the Kodiaq are comparable to those in a MKII Octy Scout, they'll both fit easily in one of them.
Good shout about the first aid kit from IKEA and the dry powder extinguisher too.
I actually used the little torch yesterday as I ran out of daylight halfway through hovering the car... Worked a treat :)
14 hours ago, lowedb said:
Can't get mine to Hover no matter what I tried.
You have to fit the flux capacitor first, then you can go back to the future to fit the hover conversion :biggrin:
The torch is useful however mine did not work when I finally went to use it. Lit up in situ but not when taken out. I took the batteries out to have a look and managed to split the case. Really annoying. The batteries in mine appeared not to charge. I decided to purchased another one on ebay, plugged it is and it works fine. So my only advice is if you open it up be gentle.
I've never managed to get the torch out - is there a trick to this?
At the rear of the torch there’s a small latch that pops the torch out.
