Custom POI loading - snookered?!
Hi
I've downloaded some custom POIs, ran them through Skoda MyDestination, and loaded them to an SD card. The Amundsen instuction manual says:
Quote
Import
› Insert the SD card with the POI categories into the device.
› Press in the Navigation menu the function key  → Version information →
Update.
› Select the SD card as the source and confirm the import.
On my Fabia the SD card is in the glovebox. The trouble I'm having is that I can't get to the Update menu without the satnav SD card being present, and as soon I get to the menu and then swap the SD cards over I get an error message because the satnav data card is missing!
Please could someone advise me where I'm going wrong!
You have to download the POIs in the root directory (not in maps) of your navigation card
Ah, OK thanks. I'll give that a go.
