Driver side electric window goes off track when continuously closing
Hey!!
I have a used 14 reg Citigo SE, and yesterday, the window started to go all funky and began to close off-track if I closed it continuously by holding the button!! If I 'pulse' it i.e. close it bit by bit slowly, it works fine.
The car is still under a 30 day warranty from the dealer but I was curious as to how much it would cost to fix this kind of problem and whether it is an electrical or mechanical fault?
Edited by Guest
Could be a window regulator, if its got a warranty take it back and ask for it to be repaired
I did a regulator on a golf for £30-40. But don't waste your time if you've a warranty it might be more complicated. I had seat do one and that had to change are rubbers in the door frame too.
  • 5 months later...
Facing the same problem... Car is at Skoda workshop at the moment, will keep You posted on the outcome.
Is this a common problem on this little cars?
just a quick update, it was faulty window regulator. Had been replaced by the Skoda workshop as the car was under warranty :D
It makes sense to keep the window runners lubricated to ease the load on the motor/regulator mechanism.
Drop the window to its lowest point and spray the runners with a silicone based lubricant.
Same goes for the door locks too.
