How to replace driver side seat belt buckle
Hi All,
How can I replace driver side seat belt buckle?
Is need to remove the seat?
Is need to disconnect the battery? (for airbags)?
What happen when I reconnect the battery, I should be set a lot of end or default position maybe. Is it correct?
One more thing, what kind of tool/key needed for remove seat? As I know it is not torx.
Thank you in advance
Edited by ujtordai
Hi all,
In meantime I done it.
I removed the four screw which fixed the rail of the seat.
I not disconnected the battery negative or earth cable because I not disconnected the air bak cable of the seat.
The key is XYN / Spline 12pt.
