32 minutes ago, Lindsayt said:
Took my 190,000 miles 2016 Greenline Estate in for its' MOT today.
It passed with advisories on both rear shock absorbers and front suspension bushes on both sides.
I'm happy. Last year it passed with no advisories when it was on 167,000 miles.
I intend replacing the shock-absorbers myself. Probably in the spring, when it gets a bit warmer.
I'm not sure about the suspension bushes? Maybe I'll do them myself, maybe I'll get a VAG specialist to do them.
Sounds like a good justification for some bilsteins!
  • Replies 5.6k
  • Views 737.9k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
Heated steering wheel I got for a great price brand new. Had the stitching re-done to match my paint, Dragon Skin Green. Installing additional buttons for drive mode and Stop/Start. Not a brilliant fit on the casing for the buttons, the optimal position for this bracket would then have one of the screws go thru a mount guide for the MFSW centre surround. I also struggled to get the screws to go in to mount the button on the wheel, I had to drill out the holes for width and depth to suit the screws. Right PITA.
WhatsApp Image 2026-11-08 at 10.54.07 PM (1).jpegWhatsApp Image 2026-11-08 at 10.54.07 PM (2).jpegWhatsApp Image 2026-11-08 at 10.54.08 PM.jpegWhatsApp Image 2026-11-08 at 10.54.08 PM (1).jpeg
How does the wiring for the new buttons get through the clockspring?
I agree.
Would you recommend any particular Bilstein part number for my Greenline Estate? Bearing in mind it sits a little bit lower than the standard car (for the fuel economy). And that it's a comfy spacious cruising car and not a performance model, with the 1.6 TDi engine.
Edited by Lindsayt
Just now, Lindsayt said:
I agree.
Would recommend any particular Bilstein part number for my Greenline Estate? Bearing in mind it sits a little bit lower than the standard car (for the fuel economy). And that it's a comfy spacious cruising car and not a performance model, with the 1.6 TDi engine.
Personally I’m not sure but there are plenty on here who would have more knowledge than I! Does it have dcc currently or just standard shocks?
Dedicated Wifi, which is wired into the main car loom.
It has standard shocks.
The Bilstein B6 24-229890 seems to be the one to go for.
I fitted B6's to the rear of my 2010 BMW 330D 4 years ago. They've worked fine on that car.
I’d love to put eibach springs on mine but can’t justify the work to do it. So might buy them to sit in the shed awaiting it needing some suspension work….
I have a huge list of mods
And I truly don’t know where to start first 🥲
Easiest/cheapest first. Then you don’t feel so bad about spending more money on singular larger mods as you’ve achieved so much already…
Make sure you let your insurance know. Just done a renewal and declared everything and had to send photos but no change in premium as nothing is permanence changing.
Problem is.
I do car shows with it
So also want the most impact to stand out
It’s strange driving a standard car 😂
I declared my stage 1 Revo ECU remap (+80bhp) to my insurance company a few years ago & have changed insurer since then a couple of times. No increase. Having said that some insurance company's won't touch anything that's modified these days so best to check before diving in only to find out bad news later on.
I used compare the market and you have options to list all the things so then you only get quotes from insurance companies that will cover. Mine is with Hastings and just had to take about 10 photos from all angles. I suspect it now means that any tiny cosmetic change will void insurance and require a £20 admin fee to update as they have photographic evidence! I think it probably helps that I’m not a 17 year old liability with a modified car!
Edited by Binx1310
Did they say which bushes?
Recently Browsing 2
