Mk1 Sunroof panel not moving properly
Hello! Before time I realized that my sunroof panel is not moving the way it should be. It opens good but when I try to turn it back closed it goes to the middle and then again back fully opened. So I will appreciate any Ideas that might cause this problem. And if you can suggest me a way that I can get to the motors and the movement parts of the sunroof. I tried myself but it seems the upholstery on the inside of the roof is being glued so I will not be able to take it off easily neither glue it back there. Thanks in advance!
@kickbuttowski101 - Well, mine occasionally does an uncommanded open. My first suggestion would be to set the switch to "full open" when this starts to happen. If the panel stops fully open, count to 5, then set it back to closed.
Next, look for anything in the cassette that could be obstructing the panel when it's nearly closed.
