Where is radiator fan relay?
several times I try to find radiator fan relay (control unit) but I can't find it. Please let me know...
Fan is running all the time if the fuse is connected.
Edited by OH1XE
  • Sponsor
What year is your Octavia, and what type of air conditioning system does it have?
It is normally inside the main fan unit.
Model 2005 with A/C.
Radiator fans were changed. Still the bigger fan is running all the time as well the battery is empty. I thing this is the relay what I looking for.https://m.ebay.com/itm/RADIATOR-FAN-RELAY-SKODA-OCTAVIA-1U2-1997-2010-1U5-1998-2010-1J0919506k/153154766706?hash=item23a8bc4772:g:zsgAAOSwYq5bW1KL
but where it is located?
Edited by OH1XE
PS. i found Fabia relay location, but not a word of Octavia
As said the control unit is built into the main fan. The smaller fan if installed is control via LIN from the larger fan.
OK. Thank You!
I opened the fan and the are some electronics, which are not serviceable. See the photo.
So I need to buy brand new fan and problem solved.
  • 3 years later...
  • Sponsor
On 04/09/2018 at 20:36, OH1XE said:
OK. Thank You!
Considering that earlier fan designs with just a single wirewound resistor inside the housing have proved unreliable, this seems like a very bold design idea. Or strategic?
