Auto switch off headlamps.
I have a 62 plate elegance estate with a DSG box and I noticed last night that when I park up and remove the ignition key,with the headlights on, all my external lights go out but if the head light switch is on side lights only then I get the audible warning and sides stay on. Is this a standard feature or an extra? Also I don't have auto lights. Thanks.
Sorry no idea,
but i like that on cars that do that and miss it on ones that do not.
They are parking lights, it's explained in the manual ;)
Quote
Parking light
› Switch off the ignition.
› Pull the turn signal light lever upwards or downwards the side light on the right or left side of the vehicle is switched.
Parking light on both sides
› Turn the light switch into the position "sidelight" and lock the vehicle
Do you think if Is it possible that in parking lights the tails not illuminate all 4 bulbs in each of the cluster and leave for example 1 or 2 bulbs for preventing battery drainage after long time parking ?
Sure, if the car has a BCM you should be able to choose the top, two side or bottom bulbs or a combination using VCP/ODIS-e.
