Camshaft Position Sensor (G40) Implausible signal
Just got my VCDS HEX V2 cable and did an autoscan while the ignition was on for my vRS MY15 and I got these error messages. What do they mean? Do I need to get them fixed asap? Should I contact the seller? :(
VIN: TMBAE9NE0F0169541   Mileage: 52714km-32754miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0010
   Revision: --H13---
   Coding: 0C1D00322424010B0000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001014
   ROD: EV_ECM20TFS0215G0906259_VW37.rod
   VCID: 6B83C407030A0DBF5B7-803E
1 Fault Found:
14874 - Camshaft Position Sensor (G40)
          P0341 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01411171486
   Coding: 0014
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 290FFE0FC976DFAFE9B-807C
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
I cleared the faults and the first one hasnt come back yet but Lever Sensor System still pops up from time to time
I get the starter lever error persistently and haven't had any issue in the 2 years I've had my VRS.
Wouldn't worry about it unless your car starts showing problems. There is a common issue where the lever needs replacing but you'd see errors in the car's maxidot.
If you want to change the cam position sensor they're normally a pretty easy job. Just unplug them and usually unscrew one bolt. Usually around £50 for the sensor.
Wouldn't waste your time and money if it's not causing any problems though.
Hesitation, RPM dipping and sometimes even cutting out are the symptoms of the sensor going bad.
Thanks guys! I got really worried there for a while since I bought the car just a month ago but the cam position sensor fault hasnt shown up since.
How does the car show when its having problems with the starter lever error?
