Fabia vRS - Interior Air Vent
Hi there,
Please can any fellow Briskodians enlighten me as to how can the air vent be re-aligned, as the vent assembly is out of alignment relative to the outer trim surround. Therefore when you shut the vents they do not sit flush with the surround trim.
Maybe a trick one?
Thanks,
Rich
Please can any fellow Briskodians enlighten me as to how can the air vent be re-aligned' date=' as the vent assembly is out of alignment relative to the outer trim surround. Therefore when you shut the vents they do not sit flush with the surround trim.
Maybe a trick one?
[/quote']
I'm not sure they are supposed to?
Easiest solution is to take it back to the dealer and get them to do it. It's what warranties are for...
Rob.
Will do, I thought it would be an easy job.
Thanks.
Will do' date=' I thought it would be an easy job.
Thanks.[/quote']It probably is very simple, but it's very easy to snap the "flaps" on the air vents, as I've found out before..... :D
Snapped flaps :eek:
I don't know if this helps but if I understand correctly when you shut the vents they do not completely shut/stay slightly proud? I only recently discovered that the vents on my Octavia (which I'm guessing are the same?) do shut flush if you turn the wheel home ie there is a slight resistance/notch/whatever then the vents are flush.
If this isn't what you meant please feel free to ignore this post :stupid:
Snapped flaps :eek:
:rofl:
Hi,
Just an update - job sorted by my dealer, pretty quick and efficient. :Cat:
Hi' date='
Just an update - job sorted by my dealer, pretty quick and efficient. :Cat:[/quote']
Job done. As they say. :thumbup:
