Remote locking
How do I remove audible warning on locking and unlocking my car
IIRC it's in the MFD, but it is also key dependent do you have to do it for each key.
Same for daylight saving, nave been able to figure that one.
10 hours ago, Gdcobra said:
daylight saving
9 minutes ago, superbdreams said:
When you change from BST to GMT (as we did a couple of weeks back) you simply turn the daylight saving from off to on which is good.  BUT if you then open the car with the other key  the setting will revert, or more accuratly will be whatever is set to that key.
It's only a small thing but easy to forget and I can't understand why its not a global, "car" setting rather than "user" setting.  I guess if you are the sole user of the car you could have one key set to winter and the other for summer but i'd have thought most users would use both keys interchangably or one for each user as I do (so that the the seat moves automatically).
In any case I don't understand why it's not automatic, particulary in a car with GPS/Sat Nav'.  It's is on my other car, which surprised me as it's an analogue clock and that does not have GPS.
Mind you it doesn't do many  things which the Skoda does so not comlaining
Edited by Gdcobra
I did not know that, thank you :biggrin:
I only found out due to an irate phone call from my wife earlier in the year when she thought she'd missed an appointment due to the clock not being set correctly.
When I checked found it was only correct for my key.
You don't forget that kind of thing in a hurry!
so setting the clock is solely your responsibility then...how fair B)
As with many things they are my responsibility when they are not done.  Or not done properly.
So the vehicle will display a different time according to whichever key is used?
They must think that some people live in a parallel reality :D
Mind you it would be usefull when I bring French friends to the UK, they usually refuse point blank to change their watches and even if they did their stomach clock would send them into shut down mode between 12.00 and 14.30 CET :biggrin:
