Can't get s7edge to play music in superb 2013
Does s7edge play music through Columbus setup in superb 2013
Should be able to.
It might depend what bluetooth module is fitted so I'd suggest you check that first. I think it's under one of the front seats in the Superb?
Phon couples so I can use the phone just can't get play music via Bluetooth
make sure you are in media mode on head unit?
The BT module part number would still be helpful as not all support music streaming.
If the BT module is ok does media player not need turning on in maxidot. I know mine is turned off because I don't need it
It worked with s6 edge so i presumed it would work on s7edge
Edited by Razzertrevor
Wrong information
Just sorted the maxidot and I'm coupled thanks ashfan better than the manual
