Remote unlocking issue
Had a new battery fitted by Kwikfit
Fob will lock all doors and will unlock boot but will not unlock doors
Kwikfit claim it was a problem before new battery fitted - but it all worked fine before batter change
What happens if you press unlock twice?
If that works, it sounds like a setting has reset. If you have a maxidot cluster you can probably change it there, otherwise someone with VCDS or similar can make the change for you.
New battery fitted ................in the car...............or in the fob??????????
in the car
