Skoda Octavia 2014 power steering fault
My red power steering light & esc light has come on ,resulting in no power steering. I don't know if it's a ECU problem. I know my track rod ends need doing could this be causing the problem ??
A y advise would be helpful thanks.
A 2014 might be a MK3 rather than a MK2.
Still, the best plan is a scan with VCDS or similar to check for fault codes.
Yeh it is mk3 ,
This any help?
Had it checked again today came with airbag module which somehow makes you lose power steering & esc (modern technology eh)
Had it plugged in today & its come up with airbag module which somehow interferes with your power steering hopefully it only a loose connection.
