heated mirror
19 hours ago, Smileyman said:
I presume when you say "open" you mean "switched on" and heated mirror you mean rear window (or door mirrors?) ... you can't the system automatically switches off after a few minutes
i say for the mirror heater my friend , if I forget the heating of the mirror open, it will be destroyed or it will shut itself off on its own.
15 minutes ago, gogosnat said:
how can I do this ?
You need Carista, OBDEleven or VCDS.
Carista is the cheapest and simplest option, I believe
It  allows a limited amount of vehicle customisation, as well as full diagnostics.
I don't think there is enough heat to burn out, so to speak, particularly in the winter. It may shorten the elements life, with fair wear and tear though. It will also contribute to flattening the battery over time.
