Octavia mk1 - electrical problems
Hello everyone, new user here!
I own a Octavia mk1 2003 and i'm having some electrical problems.
The cooling fans run constantly, and the strangest problem i have is i can take the key out of the ignition but i can still roll the windows down and use the wipers!
I talked to some car electrictian and he said i probably have some fried relays but he said he wouldn work on that.
Looking forward to your replies!
@SLOctavia2003
Iirc correctly, the windows thing is normal. They should work until you open a door. If they still work after the door is opened, something is goosed.
Wipers maybe the same, i cant remember.
Cooling fans constantly running has been covered many times, cant remember the common cause, as it never affected my car, might have been a secondary air pump thing.. or something totally different.
Edited by mac11irl
Thanks for the reply, forgot to mention that the central locking is out also, atleas with the key buttons.
Just found a capable electrician nearby who loves old tdis, taking it in for a checkup tommorow morning.
Will report how it went!
@SLOctavia2003 - You don't state a trim level. Fans running at all times is normal if you have Climatronic, or have manual AC turned ON.
The trim level is Elegance i think. I have ckimatronic but it is turned off all the time.
Will take a look at the thread, thanks.
