1.9 TDI BXE camshaft
Hi,
Through on-line research, I think my 133k 1.9 TDI BXE engine is showing the symptoms of camshaft wear.
Does anybody know of a trusted and competent mechanic near the Medway Towns that would be able to confirm my diagnosis and rectify the problem.
Regards
Paul
On 15/01/2019 at 18:38, PD_Paul said:
Hi,
Regards
Paul
How much were you charged? I've been quoted 1000
Hi,
Regards
Paul
this is the same noise that I'm getting
I had a worn cam shaft at c. 140k and went to a guy near Sevenoaks. He did the timing belt and water pump at Tue same time and I think it was £1,100.
I can look the name of the place up if you wish?
Best
Matt
Best
Matt
Yes please, thank you. although I won't be needing cambelt and pump changed as they're fairly new!
Thank you for your replies.  I've had the camshaft replaced by a local garage.  I supplied the camshaft kit which I bought from Darkside Developments.  Total cost was £800
Best wishes
Paul
Hello
Sorry for the delay, I will look it up  this morning for you.
Matt
Hi,
It was Fox's Garage, Otford lane, Halstead, TN14 7EG.
01959 534 098
Best
Matt
