Door Handle Problem
Passenger door on our Fabia won't open from the outside. Works fine from the inside. Handle moves ok, but makes a "clicking" noise. I guess something is broken or loose? Anyone had a similar problem or know the cause?
I had something similar with the rear offside door when the garage were repairing the water leak on that door. Apparently a cable or somesuch wasn't adjusted right on re-assembly of the door panel, took about 5 minutes for them to fix.
I'd drop it into the dealer if it's under warranty, if not hopefully someone knowledgable may be able to tell you what to adjust :)
If this is like the Passat, you remove a black plastic cap from the side of the door (where the latch is), undo a allen screw and part of the outside handle comes out. There's a little wire cable with a plastic retainer which links the outside of the handle to the door mechanism. It had a habit of coming off it's catch in the Passat . . just a thought!
thanks everyone, I'll take it to bits over the weekend, weather permitting!!
