Audio control and titles over bluetooth
Hi,
I have a factory fitted Swing HU and a bluetooth module.
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0081
   Revision: 0I001001    Serial number: SKZ1Z2M0064464
   Coding: 0D0004000001
   Shop #: WSC 73430 790 00064
   VCID: 316973E168F8C9C970-8064
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661787535
   Coding: 0201000000010110
   Shop #: WSC 73430 031 00064
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275D9DB95E3C8779AE-8072
Currently when I switch to bluetooth audio the stream works fine, but only "BT-Audio" is on the Swing's screen instead of Artist, Title, etc. And I also can not control the phone(s) via the HU (my phone is a Samsung SM-G361F, wife has Xiaomi MiA1).
Is it possible at all? If yes, then what do I need? Coding mod and/or hw retrofit?
Edited by mucden
I'm not 100% sure what's needed to get full track info and skip track functionally. I think it's a combination of both the headunit and BT module.
My RNS-310 (3T0 035 191 A) in combination with 3C8 035 730 D/E let me skip tracks but no track info. When I replaced the RNS-310 for a RNS-510, it would show track info too.
At a guess, changing the BT module *might* give you the ability to skip tracks. No idea if the Swing can do track info though.
I've found this post as a probably relevant and sad answer to my question:
