Octavia 2010 retrofit HBA without maxidot display possible ?
Hello my friends :)
I have bought a HBA mirror from one of my friends. It worked fine in he's car, which is exacct the same as min, but for the maxidot display.
We have the same BCM, with same hw and sw versions, we both have factory fitted rain/light sensor, and the returning beam stalk.
In he's maxidot display i got an HBA icon, telling him that the assistant was active. I knew, as i didnt have maxidot, that i could not have this icon, but i assumed it would work despite that. Know i got doubts if there is some kind of logic functionality in the cluster regarding the HBA assistant, and its not just a dum icon that the canbus tells the instrument to turn on, an thats it. Do any of you guys know if my HBA will work without the maxidot cluster ?
2. Has any of you guys experience with the RCD 330 from chinese market ? I have amundesen+, but i really think the navigation suck, but Im totally satisfied with the rest of the amundsen. For eksample in my city is does not know when left turns are prohibited, and many oneway roads which are 5 years old it does not know either. First i thought it was the map (v11 for rns-315 west europe at ebay for £38), but then i got on yo navteq's website were they have a route planner called we-go or something like that, and that route planner didnt know the one way streets either, so i figured there maps are ****ty!
Are you all happy with the way the amundsen+ or rns-315 navigates ?
BR
Mikkel Denmark
Can you post an autoscan with the HBA camera fitted?
Rcd330 is mostly ok. Biggest issue I had was the lack of RDS and AF on FM radio. There are a few other bugs around Bluetooth and sound levels. It'll depend what firmware and hardware it has. It doesn't do DAB or navigation either.
Can't comment on the rns315 maps im afraid... :-)
Yes, here is the autoscan from my friends car with maxidot, and halogen beams, HBA working.
I also have autolight.
My car has this instrument:
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 K    HW: 1Z0 920 803 K
   Component: KOMBI         H04 0405
   Serial number: 00000000000000
   Coding: 510B00
   Shop #: WSC 36786 001 104857
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 3C77D27BB79E7CFE88B-8069
No fault code found.
Autoscan with HBA working:
VIN: TMBGJ61Z3B2133113
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 E    HW: 03C 906 016 C
   Component: MED17.5.5       G   9970
    Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 52498 001 1048576
   VCID: 21490306F869E716BBD-8074
2 Faults Found:
001384 - Cruise Control Switch (E45)
               P0568 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 63300 km
                    Time Indication: 0
                    Date: 2056.14.30
                    Time: 16:35:27
             Freeze Frame:
                    RPM: 706 /min
                    Load: 34.9 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 13.843 V
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 63300 km
                    Time Indication: 0
                    Date: 2056.14.30
                    Time: 16:35:27
             Freeze Frame:
                    RPM: 706 /min
                    Load: 34.9 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
                    Temperature: 13.0°C
                    Voltage: 13.843 V
Readiness: 1110 0001
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 050 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     411 9060
   Revision: 00041014    Serial number: CU501103025291
   Coding: 0000020
   VCID: 2A5BE42A855F244EEA7-807F
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C092500FD880C04E5901C0040370C00
   Shop #: WSC 73430 790 00085
   VCID: 76E3005AC16730AEBEF-8023
1 Fault Found:
01486 - System Function Test Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 63300 km
                    Time Indication: 0
                    Date: 2056.14.30
                    Time: 16:40:37
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 320
                    Count: 50688
                    Count: 57600
                    Count: 1021
                    Count: 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 76E3005AC96730AEBEF-8023
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E00508C040080088300081E0477839AE417D8D605C8560200040
   Shop #: WSC 01723 013 01313
   VCID: 387FCE628BF386DE6C3-806D
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 02031  26  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 080311 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28291105225955
   Coding: 310101
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_SK35.rod
   VCID: 4385A98ECA35D506C91-8016
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC24CAKA
   Coding: 0020790
   VCID: 3D71DF7664D1A3F6BF5-8068
   Subsystem 1 - Part No: 1K0 909 605 T
   Subsystem 2 - Serial number: 6332MSME5C560A26H
   Subsystem 3 - Serial number: 6342MSME5C346F2AT
   Subsystem 4 - Serial number: 6351HSME26566E05B
   Subsystem 5 - Serial number: 6361HSME265D42134
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110309200514
   Coding: 1892040000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7CF71272F74B6AFEC8B-8029
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  X03 X009
   Coding: 830000
   Part No SW: 1Z0 920 843 K    HW: 1Z0 920 843 K
   Component: KOMBI         H20 0420
   Coding: 110A01
   Shop #: WSC 73430 031 00085
   VCID: 408FA682DB23CE1ED43-8015
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 070311F1003688
   Coding: 352302
   VCID: 306FF64263835E9E243-8065
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0101196B74745D545420363E00
   Shop #: WSC 01324 020 00200
   VCID: 2E53E83A79B7486E36F-807B
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: EADBA42A0DDF644EAA7-80BF
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 K    HW: 3T0 035 680 K
   Component: RNS-MID       H72 5269
   Revision: AB001001    Serial number: --------------
   Coding: 00000400000100813000
   Shop #: WSC 13948 123 10485
   Subsystem 1 - Part No: 3T0 051 859 AL
   Component: EU West V13  8348
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 63296 km
                    Time Indication: 0
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0000246
   VCID: 76E3005A016730AEBEF-8023
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 3467FA52579B62BE40B-8061
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000246
   VCID: 489FBEA23B13F65E1C3-801D
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 63296 km
                    Time Indication: 0
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012565
   VCID: 326BFC4AAD8F6C8E527-8067
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Towbar module H09 0100
   Revision: 3A001001    Serial number: ÀÁ006789000000
   Coding: 0100000100000000
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525 PA8J330919
   Coding: 0030011
   VCID: EED3A83AF937886EF6F-80BB
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3365F94E52956586591-8066
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00AAAA63112800
   Coding: 0010000000010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B75D16EB2C5ADC6811-806E
It's the full autoscan from your car that's needed... Including the header ideally.
Ok sorry i misunderstood, but as far as i can see we have the exact same equiptment in the cars. He has a slightly newer can gateway, but in my gateway on the instalation list, there is also room for module 20.
My scan:
Fredag,28,December,2018,20:56:02:32356
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 7 x64
VCDS version: NEZ 18.9.0.2  HEX-V2 CB: 0.4437.4
Dataversion: 20181005 DS296.0
www.vcds.dk
Stelnummer: TMBCM61Z0B2017650   Indreg.nr.:
Modeltype: 1Z-SK35 (7N0)
Søgt på: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72
Stelnummer: TMBCM61Z0B2017650   Kørestrækning: 207220km
01-Motor -- Status: Ok 0000
03-ABS bremser -- Status: Ok 0000
04-Styrevinkel -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
16-Ratelektronik -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
25-Startspærre -- Status: Ok 0000
37-Navigation -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Ok 0000
46-Komfortelektronik -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
56-Radio -- Status: Ok 0000
62-Dørelektr. V bag -- Status: Ok 0000
69-Anhængertræk -- Status: Ok 0000
72-Dørelektr. H bag -- Status: Ok 0000
Styreenhed  01: Motor (J623-CBZB)     Forklaringsfil:. NEZ\03F-906-070-CBZ.clb
   Styreenhedsnr: SW: 03F 906 070 F    HW: 03F 906 070 F
   Komponent    : SIMOS10.10H03 9837
   Revision: --------    Serienummer:
   Kodning    : 001900D6232400080000
   Forhandler    : WSC 73430 031 00000
   ASAM datasæt: EV_ECM12TFS02103F906070F 003011
   ROD: EV_ECM12TFS02103F906070A_003_VW32.rod
   VCID: 2517F3970566E06FCD3-8070
Ingen fejlkoder fundet.
Readiness: 0000 0000
Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\1K0-907-379-60EC1F.clb
   Styreenhedsnr: SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
   Komponent    : ESP MK60EC1   H30 0105
   Revision: 00H30001
   Kodning    : 113B201C09230001881104E990190040340000
   Forhandler    : WSC 36786 001 104857
   VCID: 03538D0FAB12FE5F837-8056
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\5K0-907-044.clb
   Styreenhedsnr: SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Komponent    : Climatronic   H15 0401
   Revision: 00005001
   Kodning    : 0000000002
   Forhandler    : WSC 73430 790 00000
   ASAM datasæt: EV_Climatronic A01006
   VCID: 03538D0FAB92FE5F837-8056
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\1K0-937-08x-09.clb
   Styreenhedsnr: SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Komponent    : BCM PQ35  H   103 0615
   Revision: 00103 AD
   Kodning    : 40180AB8E83308C040100080110081E4467100AE527D8D605C0540200040
   Forhandler    : WSC 73430 790 12345
   VCID: 38292AE3A2546D87665-806C
   Undersystem 1 - Styreenhedsnr:: 1Z1 955 119 C  Forklaringsfil: NEZ\1KX-955-119.CLB
   Komponent    : Wischer 17061  22  0601
   Kodning    : 00DF97
   Undersystem 2 - Styreenhedsnr:: 1K0 955 559 AH  Forklaringsfil: NEZ\1K0-955-559-AG.CLB
   Komponent    : RLS 180610 05  54  0403
   Kodning    : 0730ED
Styreenhed  15: Airbags      Forklaringsfil: NEZ\1K0-909-605.lbl
   Styreenhedsnr: SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Komponent    : Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serienummer: 0038PC1YJC2U
   Kodning    : 0020790
   VCID: 3D273BF7817648AFB53-8068
   Undersystem 1 - Serienummer: 6332MSME5413217A4
   Undersystem 2 - Serienummer: 6342MSME53446574A
   Undersystem 3 - Serienummer: 6351HSME225C61588
   Undersystem 4 - Serienummer: 6361HSME225C6013%
Styreenhed  16: Ratelektronik (J527)     Forklaringsfil:| NEZ\5K0-953-569.clb
   Styreenhedsnr: SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Komponent    : LENKS.MODUL   009 0136
   Revision: FF010036    Serienummer: 20100628300014
   Kodning    : 5080140000
   ASAM datasæt: EV_SMLSNGVOLWS A01004
   VCID: 77ABE9DFEF4AA2FFAFF-8022
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5K0-920-xxx-17.clb-SRI1
   Styreenhedsnr: SW: 1Z0 920 803 K    HW: 1Z0 920 803 K
   Komponent    : KOMBI         H04 0405
   Serienummer: 00000000000000
   Kodning    : 510B01
   ASAM datasæt: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 3C2136F396EC41A782D-8068
Styreenhed  19: CAN Gateway      Forklaringsfil:. NEZ\7N0-907-530-V1.clb
   Styreenhedsnr: SW: 7N0 907 530     HW: 1K0 907 951
   Komponent    : J533  Gateway   H27 0602
   Revision:   H27       Serienummer: 180610F2001047
   Kodning    : E9807F4640020200001302
   Forhandler    : WSC 36786 001 1048576
   VCID: 6D87CBB79196182F453-8038
Styreenhed  25: Startspærre (J334)     Forklaringsfil:| NEZ\5K0-920-xxx-25.clb
   Styreenhedsnr: SW: 5K0 953 234     HW: 5K0 953 234
   Komponent    : IMMO          H04 0405
   Kodning    : 000000
   Forhandler    : WSC 00000 000 00000
   ASAM datasæt: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC0ABACF80F17201-803E
Styreenhed  37: Navigation (J794)     Forklaringsfil:| NEZ\1K0-035-27x-37.clb
   Styreenhedsnr: SW: 3T0 035 192 Q    HW: 3T0 035 192 Q
   Komponent    : RNS315-EU   H70 0417
   Serienummer: SKZAZ2N0300011
   Kodning    : 040004110400000000000001
   Forhandler    : WSC 31655 001 1048576
   ASAM datasæt: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   Medie:
   Undersystem 1 - Styreenhedsnr:: 3AA 919 866
   Komponent    : EUR_W_V4  0050
Styreenhed  42: Dørelektr. V for      Forklaringsfil:. NEZ\1K0-959-701-MIN3.clb
   Styreenhedsnr: SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Komponent    : Tuer-SG         009 2119
   Kodning    : 0000244
   VCID: 48C95A23DEB41D07165-801C
Styreenhed  44: Servostyring      Forklaringsfil: NEZ\1K0-909-14x-GEN3.clb
   Styreenhedsnr:: 1K0 909 144 J
   Komponent    : EPS_ZFLS Kl. 67     3001
   Revision: 00H17000
   VCID: 313F17C74D2EBCCF21B-8064
Styreenhed  52: Dørelektr. H for      Forklaringsfil:. NEZ\1K0-959-702-MIN3.clb
   Styreenhedsnr: SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Kodning    : 0000244
   VCID: 47CB591FD3AA127F1FF-8012
Styreenhed  62: Dørelektr. V bag      Forklaringsfil:. NEZ\1K0-959-703-GEN3.clb
   Styreenhedsnr: SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Komponent    : Tuer-SG         007 2101
   Kodning    : 0000144
   Forhandler    : WSC 73430 790 1012544
   VCID: 323D18CB482887D7581-8066
Styreenhed  69: Anhængertræk (J345)     Forklaringsfil:. NEZ\1K0-907-383-V2.lbl
   Styreenhedsnr: SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Komponent    : Anhaenger     H09 0100
   Revision: 3A001001    Serienummer: 00008030282144
   Kodning    : 0100000100000000
   VCID: 303912C34A24B5C72E5-8064
Styreenhed  72: Dørelektr. H bag      Forklaringsfil:. NEZ\1K0-959-704-GEN3.clb
   Styreenhedsnr: SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Kodning    : 0000144
   VCID: 33331DCFB7328EDF537-8066
Slutning-(Forløbet tid: 00:57, VBat. start/slut: 11.9V/11.9V. VIgn 11.8V)--
I was hoping the HBA camera would be installed to see if it had any fault codes present.
It could be the instrument cluster causing the issue as it may refuse to activate if no warning light can be shown. Is your headlight switch in the 'Auto' position?
When you coded the BCM, did you set it to all 00's and then put the new lcode in? Sure I've seen this suggested elsewhere.
Other than that, your ABS, gateway and steering assist (44) modules are all older. It could be any of these too. Gateway is relatively cheap to replace, steering assist can be updated, the ABS is probably OK.
Oh i think you are misunderstanding me. It is not fitted yet.
If you look at my first post, all i di is asking if a maxidot display is mandatory for the HBA to function. I know that when i have the small cluster i will not get an icon that the system is active, but will it work, alså without the icon in the cluster ?
Sorry - I misunderstood. I read it as you'd already fitted it but it wasn't working...
All I can suggest is you try wiring it up and see what happens. It's not a common retrofit on the Octavia and I expect everyone that has fitted HBA already had a maxidot.
I just did a quick google and there are no obvious examples of an Octavia with HBA with a non-maxidot cluster :(
