Mk3 Door card removal
Hi Guys,
as title - I need to change the driver's window switch and believe I need to remove the door card.
before I start, has anyone produced a walkthrough for this?
Any help would be appreciated
Thank you
Pretty sure I've seen one on YouTube as I looked Into this a few weeks ago
You don't need to remove the door card to take the window switch out. You need to lever it out. It actually blocks a bolt that holds the door card on. It's held in with 3 clips on each side, be careful not to stress the plastics or damage it when removing.
Thanks for the help - Will have to take a look at this.
does it require a lot of force to remove it?
Yes, but controlled. It’s easy to break a clip or leave stress marks on the trim.
Thank you
thanks for the top reply, removed in a matter of seconds with no damage caused.
Lets hope the issue i have with the switch is actually the switch
