Flashing glow plug warning light
I agree.
1 hour ago, J.R. said:
I agree.
Wondering what might be causing the glow plug light to flash when driving
Could be a number of things, probably worth getting it scanned with VCDS or similar to give you some idea :)
I had that last year on my CR diesel VRS.
shortly after DPF light came on and then limp mode.
turns out it was a turbo actuator valve (or something similar, it’s quite common according to the garage) had broken, fixed, good as new. About £175 plus fitting I think. Much cheaper than a new dpf
Deleted double post
Edited by Rorytavia
Thanks for that rorytavia going on the scanner today . I will post results.
