Door lock
Hi,
front right doors doesn't want to lock or unlock remotely. Manually it locks and unlocks without any problems. Other 3 doors locks and unlocks great. The window motor and the window lifter was changed in the autumn. Where should I search for the problem?
Check the door loom for continuity around the rubber grommet area in the door shut, you probably have a broken wire in the door loom.
Edited by kentphil1
Ok, I will check it, Thanks
And the multi plugs for corroded pins..
