Drivers window
Hi, new to here need help. This is my first Skoda(Superb 2010 3T5) must say I love it, anyway having issue with drivers window, pulled up at work pressed button to lower window no problem, pressed to raise window again no problem. On leaving work pressed button to lower window and Nothing, changed the black box behind door card Nothing changed switch panel and Nothing. Any ides plz all other Windows work fine and window motor works as tested whilst door card off. Help plz. Many thanks.
Check for broken wire in the loom between door and pillar
Common problem
Also changing the "black box" door controller behind door card needs recoded to car with vcdc even if supplied new from dealer..
Thank you Del8oy, for quick reply. Have ordered the VCDC, so should b here soon but will try the Loom first, I take it that cable from the loom goes up into the black box then out to various units in the door?. Again many thanks.
+1 for loom, that's what it was on my car.
