Blocked throttle Position Sensor G69 VCDS scan
Had the engine management light come on about 8 months ago. Haven't been able to drive the car for the last 6 months (was going to put in to the garage before now). Have now had it serviced and the dealer has confirmed the problem. It will cost 1.90 hours labour to clean it. I have trust in my dealer, long term trust.
It had the "fix" almost three years ago. It is a 140 2ltr diesel 12 reg with 92k miles.
Your help/input/advice would be appreciated.
Bob
Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JB    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H24 9978
   Revision: 42H24---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 37633 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018JB 003004
   ROD: EV_ECM20TDI01103L906018JB.rod
   VCID: 73E5B186DA9CC0DC29-8026
1 Fault Found:
5286 - Throttle Position Sensor (G69)
          P0121 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 145198 km
                    Date: 2018.08.13
                    Time: 15:23:06
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 12.680 V
                    Unlearning counter according OBD: 38
                    Air mass: actual value (mg/stroke): 439.0 mg/stroke
                    Throttle valve adapter: specified value: 0.00 %
                    Throttle valve adapter: actual value: -0.78 %
                    Throttle valve adapter: offset closed: -12.40 %
                    Throttle valve adapter: status-Bits 0-7: 0
                    Throttle valve adapter: status-Bits 0-7: 8
                    Throttle valve adapter: status-Bits 0-7: 55
                    Throttle valve adapter: status-Bits 0-7: 2
                    Throttle valve adapter: uncond voltage actual value: 923.6 mV
Edited by Danny 57
The throttle position sensor is behind the radiator on the air inlet pipe attached to the inlet stub.
The EGR connects to the inlet stub just above the throttle valve.
EGR gas with all its particulates condense in the stub, then run down under gravity into the throttle valve & gunge it up.
Fairly easy to remove the throttle valve & clean it.
While removed, clean out all the gunk in the inlet stub where the EGR discharges.
Cheers PipH.
Also just to mention that the DPF won't regenerate while the throttle valve has a fault.
  • 4 weeks later...
Got my car back yesterday. Service, brake fluid and mot done.
Also had the original Blocked throttle Position Sensor G69 totally cleaned including the spigot noted by PipH, thank you.
Total cost £185.68.
Oh by the way even though the car is over 7 years old (93k miles) and the "fix" was done 2 years ago early last August, Skoda paid for that part to be stripped and cleaned. There were circumstances as I had reported it last August but had not been able to get the car to the garage until a month ago (illness). The dealer (Senior service receptionist Jenny Cox) was extremely helpful in supporting my claim as was Martin Bergman (Skoda CS) to get Skoda to pay.
Very pleased just to be driving my car after nearly 7 months and especially pleased with the above outcome.
I will be putting this on the dealer page as well.
