Buzzing from AC
So a little while ago I picked up my other half from the train station and as I popped out the car to load her suitcase I noticed a bit of buzzing. After a bit of investigation, it only does it when the A/C on the climate control is on. It's not really noticeable in the cab, but outside its noticeable. Doesn't change with rev's/movement. It's been about 10 years since the last car I had with air con, so not sure if this is a normal thing. I did mention it to the dealer recently when they updated the stereo and the said it wasn't bad enough to be able to diagnose and to see if it develops.
Grabbed a quick vid with and without the AC on so you can see. This normal? The air con seems to work fine, almost freezes my hand on LO.
Edited by Confused_Cheese
It's the same on mine and a friends, so i would think it's probably normal.
