Fog light
Am codat aici despre ambele lămpi de ceață, dar tot nu merge la dreapta ... deși codarea mi-a făcut exact ca forumul (cred că ...) Are importanță că este pauză sau normal? Normal bulb not led
You'll get more help if you post in English B)
I coded here about both fog lamps but it still does not go right ... although coding made me exactly like the forum (I think ...) Does it matter whether it's break or normal? Normal bulb not led
I have coded here about both fog lamps, but it still does not go to the right ... though coding I did exactly like the forum (I think ...) Does it matter that it's break or normal?
4 minutes ago, PetrolDave said:
Veți primi mai mult ajutor dacă publicați în engleză B)
Sorry if is not in english post... autotranslate...
On my MY15 Octavia I followed the instructions on the forum to enable both rear fog lamps and it worked OK.
But, I'm assuming that you have a left-hand drive car so you should check that the forum instructions are correct as they may apply to right-hand drive cars?
If you used VCDS it might help if you post the AdpLog.csv file that VCDS saves in the \Ross-Tech\VCDS\Debug folder on the PC you used - just open it in a text editor and copy and paste it.
I have a hunch that only right hand drive cars have both fog lights as Skoda provide more cars for the left hand drive market than they do right hand drive so only fit the extra fog light to the right hand drive models and code out the bulb not legally required for the UK. I could be wrong but there have been comment on here that some cars notably left hand drive do not have the right hand (nearside) bulb fitments installed.
I’ll second this. I also think this may be the case.
