Help please ladies and gents. MFSW & phone coding
Help please guys;
I have added a MFSW and BT module to the car today and I am getting the following faults on VCDS.
Am I right in thinking the steering wheel fault may be mechanical/electrical as opposed to coding? Everything appeared to click into place as it should do but I will pull it apart again if you suggest I should.
The phone one I have looked at the coding and read quite a few threads on it but I can't clear them either.
Any help woud be much appreciated.
Mk2 PFL vrs estate.
Saturday,20,April,2019,15:41:27:52369
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0003042
Shop #: WSC 06441 785 00200
VCID: 015F87E90D05C31F913-8054
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662221633
Coding: 0210000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2615F475C86BC427C41-8072
2 Faults Found:
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 228765 km
Date: 2000.00.00
Time: 13:24:48
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
[Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 228765 km
Date: 2000.00.00
Time: 13:24:48
End----------(Elapsed Time: 01:04, VBatt start/end: 12.4V/12.3V)-----------
VCDS Version: 18.9.1.0 is that the most up to date version !!!!!
According to Rosstech, yes
Coding for the Bluetooth module appears to be incorrect. Looks like you need to address the coding issue only for that to work.
MFSW I have no idea but I would guess maybe your steering wheel controller doesn't support the new wheesl buttons?
What part number are your MFSW buttons?
A full autoscan is always helpful too :-)
The MFSW is a MK2 fl wheel with the bog standard buttons - I think I've figured that bit out, a mistake on my part d'oh
I also think I've figured out the open circuit. I got a cable from carsystems.pl and clicked it together with the sds/no sds clipped together as SDS, does that sound like why I have the open circuit?
I only posted the faults I didn't think it was worth posting the non fault bits of the scan, sorry.
