Octavia Mk1 lambda errors
Is there anyone who know if the mk1 Octavia (1.6 BFQ) what is first, and second lambda heating resistor voltages? 1. lambda is broadband, and to resistor comes ~ 5V. the same voltage goes to the 2nd lambda. I have "Open Circuit" error codes, but the resistor is not broken. about 10 ohms. Previous owner said the car used to be jerky and he got fixed it in workshop, and something was made for the car, no information whatsoever, now runs at least normally.
  1. Chassis Type: 1U (1U - Skoda Octavia (1997 > 2011))
  2. Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
  3.
  4. VIN: TMBHX41U632775628   Mileage: 294050km/182714miles
  5. -------------------------------------------------------------------------------
  6. Address 01: Engine        Labels: 06A-906-033-AVU.lbl
  7.    Part No: 06A 906 033 BG
  8.    Component: SIMOS33 1.6l 2VG00HS4600
  9.    Coding: 00031
  10.    Shop #: WSC 31480
  11.    VCID: 65C1571FFF941D36075-5072
  12.    TMBHX41U632775628     SKZ7Z0C1862708
  13.
  14. 3 Faults Found:
  15. 16514 - Oxygen (Lambda) Sensor B1 S1
  16.             P0130 - 35-00 - Malfunction in Circuit
  17. 17526 - Oxygen (Lambda) Sensor Heating; B1 S2
  18.             P1118 - 35-00 - Open Circuit
  19. 16524 - Oxygen (Lambda) Sensor B1 S2
  20.             P0140 - 35-10 - No Activity - Intermittent
  21. Readiness: 0000 0000
  22.
  23. -------------------------------------------------------------------------------
  24. Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
  25.    Part No: 1C0 907 379 K
  26.    Component: ASR FRONT MK60      0103
  27.    Coding: 0013313
  28.    Shop #: WSC 31480 000 00000
  29.    VCID: 326BFC43AEDABA8E527-5000
  30.
  31. No fault code found.
  32.
  33. -------------------------------------------------------------------------------
  34. Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
  35.    Part No: 1C0 909 601
  36.    Component: 0F AIRBAG VW51      0008
  37.    Coding: 12358
  38.    Shop #: WSC 31480
  39.    VCID: DDB1FFFF57C4D5F65F5-5000
  40.
  41. No fault code found.
  42.
  43. -------------------------------------------------------------------------------
  44. Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
  45.    Part No: 1U0 920 811 B
  46.    Component: KOMBI+WEGFAHRSP VDO V10
  47.    Coding: 23113
  48.    Shop #: WSC 31480
  49.    VCID: 2D51EF3FE7E4E5760F5-5000
  50.    TMBHX41U632775628     SKZ7Z0C1862708
  51.
  52. 1 Fault Found:
  53. 01336 - Data Bus for Comfort System
  54.             80-00 - Single-Wire Operation
  55.
  56. -------------------------------------------------------------------------------
  57. Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
  58.    Part No: 6N0 909 901
  59.    Component: Gateway K<->CAN    0001
  60.    Coding: 00006
  61.    Shop #: WSC 31480
  62.    VCID: F0EFB64BB056489EE43-5072
  63.
  64. 1 Fault Found:
  65. 01336 - Data Bus for Comfort System
  66.             80-00 - Single-Wire Operation
  67.
  68. -------------------------------------------------------------------------------
  69. Address 46: Central Conv.        Labels: 1C0-959-799.lbl
  70.    Part No: 1C0 959 799 A
  71.    Component: 4R Komfortgerát HLO 0003
  72.    Coding: 00067
  73.    Shop #: WSC 31480
  74.    VCID: 3561C75F0FB4ADB6775-49D8
  75.
  76.    Subsystem 1 - Part No: 1U4959801D
  77.    Component: 4R Tõrsteuer.FS KLO 0009
  78.
  79.    Subsystem 2 - Part No: 1U4959802D
  80.    Component: 4R Tõrsteuer.BF KLO 0009
  81.
  82. 1 Fault Found:
  83. 00928 - Locking Module for Central Locking; Front Driver Side (F220)
  84.             27-10 - Implausible Signal - Intermittent
  85.
  86. End   ---------------------------------------------------------------------
