Engine and Gearbox VCDS Error Codes (PFL VRS 230)
Hi all,
Hoping someone smarter than me has seen these errors previously.
I've got a pre-facelift vRS 230 DSG.
I plug it into VCDS every couple of weeks to keep an eye on it. It's a 66 plate and has a warranty till September so I'm going to use that to its fullest while I can.
Was surprised today by two errors, one on the engine and the other the gearbox.
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0C1D00124424010B0000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C_VW37.rod
   VCID: 2E536FFC712A4E3A7F-807A
1 Fault Found:
14874 - Camshaft Position Sensor (G40)
          P0341 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 020 L    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H54 4901
   Revision: 06354004    Serial number: TFK01607080249
   Coding: 0014
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1E33BF3C018ADEBACF-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
Are these errors familiar to anybody else?
The engine error looks pretty self-explanatory so I'm going to take the log file back to the dealer which is down the road.
Regarding the transmission, is it start/stop system related?
I tend not to use the start/stop system as it's too invasive, however I enabled it the other day in traffic and the engine didn't turn off.
After digging further into the car settings, the car stated "engine needs to be running", - but it pulled off anyway and has worked again since.
Car has 14k miles on it, bought back in August on 6k and it's been flawless since.
I'm sure these start/stop systems are going to be the death of many modern vehicles.
Thanks for any help you can provide.
They're both intermittent errors, so I would just clear them and see if they come back - it's not unknown (i.e. quite common) for the electronics to throw a wobbly without there being an actual fault.
I can definitely do that.
I've been driving around for the last few days with no apparent errors on the car anyway.
Thank you for your help. :)
