Boot liner / boot mat
Looking a boot liner / mat for my Toledo and I've spotted a few on superskoda.com. A couple of questions.
Are the Rapid Limousine and SpaceBack different mats or or they interchangeable?
What are the different between the following? The first two are obviously the same kind of mat, but for the different models. Are they identical though - very similar part number?
Limousine - €69.99
http://www.superskoda.com/Skoda/RAPID/Rapid-limousine-DOUBLE-SIDED-cargo-trunk-mat-original-Skoda-Autoas
SpaceBack - €69.99
http://www.superskoda.com/Skoda/RAPID/Rapid-SpaceBack-original-Skoda-DOUBLE-SIDED-cargo-boot-mat
SpaceBack - €39.99
http://www.superskoda.com/Skoda/RAPID/Rapid-SpaceBack-heavy-duty-rubber-rear-trunk-cargo-floor-mat-with-car-silhouette
SpaceBack - €26.99
http://www.superskoda.com/Skoda/RAPID/Rapid-SpaceBack-rear-trunk-cargo-mat-heavy-duty-rubber-Original-Skoda-Autoas-product
I've also seen rigid ones on ebay. For example
https://www.ebay.co.uk/itm/New-Genuine-Skoda-Rapid-Rigid-Plastic-Boot-Tray-Liner-5JA061162/263061136573
I've got the cheaper one from Superskoda. They are incredibly well made and a perfect fit. I think that the more expensive one is simply double sided maybe(?)
The rigid Ebay one is made of that slippy plastic and will cause anything that you put into the boot to slide around and bash off the sides but the rubber one is great for keeping things where you put them. The upside is that it is probably designed for someone who is likely to put wet things in the boot to stop the water soaking  into the carpet underneath if it goes over the edge.
As for the difference in sizes I think that they will be slightly different but I didn't keep the mat out of my old notchback to compare it to my spaceback
Edited by Delberthot
ebay was way cheaper than superskoda.
I Got a really good quality tray for the Toledo made of black rubberised foam.
all the correct cutouts, excellent fit. about a 2 inch rim so no fluid spills get into the boot.
Price was certainly under £30.
It's lasted 5 years now. still in A1 nick.
Edited by camelspyyder
