missing label
Hello Guys ,
my Steering Assist  is not recognised in my VCDS ,
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 5Q0 910 143 B    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2201
   Coding: 0100001000500010
basically i need a file from VCDS\Labels   like
5Q0-910-143.*
this is missing from my VCDS
i have only the
5Q0-909-143.clb    and i need the
5Q0-910-143.clb
Install the latest vcds version and if you still have no label, ask rosstech 🙂
the file doenst exist yet!
BUT i will write my problem , because someone might knows something..
i retrofitted a Lane Assist Camera recently
 when i  made the calibration of the camera with odis  i went to the VCDS cable and made the adaptations
 for the 3 modules  5F,A5,44
i instantly
enabled successful the high beam assist,
the Traffic sign recognition ,
BUT the lane assist dont want to work.   this is what i get
i searched on internet and i found similar problems and the solution was behind module 44 (i think)
this is the camera A5 inside the VCDS , this is the error ...
Edited by Tezaman
As above, it looks like your on 18.2 update to the latest 18.9.1.
i did, and i have the same msg , the photo is old-one day!
That's two different problems you seem to be having.
If you're missing a label file on the latest 18.9.1 release, you need to contact rosstech as they might be able to help you. If you have a hex-v2 or hex-net, try the latest 19.4 beta.
If you're getting "Missing message" errors, something isn't configured correctly, needs re-parameterision or isn't compatible. You should add a full autoscan and consider asking the same question on rosstechs forum.
The message beginning "New feature! Extended UDS fault detail...." only appears when not using a HEX-V2 or HEX-NET.
The older HEX-CAN type interfaces cannot support the much longer CAN bus messages used by the newest UDS modules, hence this message appears.
