How to change door light?
How do I change lea light on drivers door fabia 2011
Edited by john999boy
Title
What is a lea light?
@BrianS78 You need to make the titles in your posts relevant instead of repeating your name. :thumbup:
I’ll alter this one again when you elaborate on a ‘lea’ light!
My guess is he means the door open warning light...
Some models have 'em, some don't!
If so, it is most likely a prise it out jobbie, using a plastic lever so as not to damage the surrounding plastic. If I am correct, it will then have a plug-in loom and perhaps a changeable bulb, which is, I assume, why he wants to know. I it IS changeable and blown be sure to be gentle as many of these sorts of lights fall apart and are tricky to reassemble or you might even have to change the whole unit anyway.
Unfortunately, I can't experiment for you as my model does not have the door lights.
LED door light maybe?
Edited by Mickmartin
