Worn wheel bearing
Hi Stuart just catching up here and I think you're seriously needing to find another garage ....the prices you're paying arid eye watering for an independent  ...you'd be almost as cheap, if not cheaper at a dealer
  • Replies 56
  • Views 7.9k
  • Golf-Fiend
    Golf-Fiend
    On a car older than 5 years I'b be inclined to fit the Febi part that Nige mentioned above that cost £55. You could probably get it fitted for under £100 at an Indy. Febi make quality parts.
  • Yep, wheel bearing is built into the hub. As is the ABS ring that the sensor uses to determine wheel speed (This is a common failure on mk2 Octavia's)
  • £135 inc VAT for the genuine part.   No, it's a hub unit not a separate bearing.
You're not wrong @labman1001! I'm still stunned by the audacity of their practices. They clearly plan for the long term because last year's test advised of a shock absorber that had started weeping which had progressed to a full-on failure of a leak this year. All makes sense doesn't it? Unless you test the theory by taking it elsewhere for a rigourous inspection. I've found https://www.whocanfixmycar.com/  and might give that a try for the next piece of work.
The good garage scheme  is another place to check for a workshop
Thanks. I'll take a look.
Pity you're not more local, i'd cut that price waaaay down.
Yes and no ..... I knew my front shocker was misting September last year, it was picked up by my garage (independent specialist) when they did work on the car In Feb and they advised and quoted a replacement cost should I want it doing.  Driving back from Glasgow last week I could feel the absorption had gone and handling characteristics of the car had changed so I got it booked in and had it changed today.
A weeping shocker (which is an advisory) will get worse which will be inevitably be a failure.
As for a wheel bearing I'd expect a noise (and a prominent one at that).  I've got a bearing on its way that shows (or should I say is audible) when driven but not evident on a ramp so I'm keeping an eye on it and will have to let it develop.  I have been quoted about £250 for genuine and I'm fairly cool with that based on my mates A3 being done at a garage who gave him a discounted rate and it came in at £180
Except, like in my case, where they get better on their own 😉
