Heater ac fan
Hi all.
Sorry if this has been asked before.
I have a 2016 superb estate. I have 2 things I would like to ask.
Firstly when I switch my ac on it blows cool air not cold but warm ish air. Dose the ac just need a re gas or is there another problem.
Second is that even when the fans are of it still blows warm air through the vents. I can only stop this happening if move all the vents to the off position. Again is this normal or again  something I need to get sorted.
Thanks simon
What temperature do you set for inside the cabin when it's blowing warmish air and what is the outside temperature?
Have you tried setting the inside temperature to low with fans on high to see if it blows cold air?
When you turn off the fans and it's still blowing warm air through the vents, is this when you're in motion rather than stationary?
I think I have fixed it.
Just been reading on another post about the same problem. They put a video up about resetting the vents. Gave it a go and it all seems good now. Cheers
OK.  Fingers crossed it's all working as it should now.
