Door control module
I had a few battery issues and it used to get discharged frequently. After a couple of battery charding sessions and finally getting a new battery, the right side window and door lock stopped working. I am able to manually lock/unlick the door.
Is is related to the Module?
Thanks.
Front or rear door? If front could be break in the wiring in the rubber boot between door and the car, or water ingress into the window motor multi plug.
If rear it’s likely to be broken wiring in the rubber boot between door and car.
Thanks @Skoda_Driver1972. The rear door is in a deadlock state. I mean the power window is working but I am unable to unlock the door manually.
