Favorit clutch and throttle cables
Hi All
Are the clutch and throttle cables different between LHD and RHD cars? I would have thought at least the clutch cable would be but I can only seem to find one option online
Wes
ok, found the "correct" clutch cable but can still only find one throttle cable...
Everything you need to know about parts is available for you in Skoda online catalogs.
There is a dedicated pinned topic in this section with various links. Don't hesitate to consult it before asking us.
Here is a link at random from that topic. https://skoda.7zap.com/en/cz/
Thanks Ricardo. I found that and did indeed see the two clutch cables hence the follow up post. I could only seem to find one throttle cable though, but the part I have bought for my car is a lot shorter than the one currently fitted, hence my wondering if there is in fact two
No, there are two if you look carefully again.
I do apologise Ricardo, you are absolutely correct. I was thrown because the clutch cable showed two different ones in the diagram but the throttle cable showed only one in the diagram, but two part numbers in the list. my mistake
  • 4 years later...
Hi, i have seen your post about clutch cables and i have clicked on the link above but clearly i am looking in the wrong place to find out a about right hand drive clutch cable for a 1994 favorit. would you mind pointing me in the right direction.  Currently trying to help my son and his mate out as they have snapped a clutch cable in Austria on a charity drive with numerous other students.  thank you.
