service indicater
my car is now telling me it needs to be serviced just 8000 miles since the last service. i know for a fact that the discs and pads on the front are getting low. will this have brought the service indicater on? if so if i change the discs and pads myself will it reset?
off to wales tomoz so really need advice tonight!!!
thanks
adam
The pad wear indicator is on the nearside front pad (the inner pad). When this has worn through the brake pad indicator light comes on (orange circle with brackets around it (O) )
However, on my car the offside pads reached a minimum level before the nearside one and hence, the pads needed changing before the indicator came on.
The service indicator has nothing at all to do with the brakes.
It may be worth taking the front wheels off and checking the pad thickness.
cheers goochie,
thats a bit of a bummer though, i thought the car would be longer than 8000 between services!!!
The Service Indicator I think comes on depending on the condition of the oil, that is, if you are on variable servicing and use the correct oil i.e. VW 506 00 or VW 506 01.
I know the dealer that did my last services amended the variable servicing to annual servicing in error and about 3 weeks ago the service indicator came on, I got then to change it back to variable servicing. I used Castrol SLX oil.
However, next time I will use Fuchs Oil (no joke her mate) from Germany and will get it from www. opieoils.co.uk and they give Briskoda members discount as well.
Fuchs Oil latest specification is VW 507 00 and apparently they work closely with VW as well.
so if i change the oil myself will the service indicator go off on its own or will it require resetting by the stealer?
adam
Indicator will need reseting by the dealer.
if on variable do NOT follow the instructions in the user manual to reset the indicator. It will mess up the schedule and put you on fixed, even though the ecu is coded for variable.
oh well, looks like i better get her booked in if i want to keep up the service record. mind you, i might change the oil myself and take the receipts in with me so they dont do it and i still get my book stamped
I had a similar thing happen, with the indicator coming on after about 8000 miles when I was expecting about 16-17K miles as I had with the previous service interval. I took the car to the dealer, and they reset the service indicator, and car continued fine for another ~8K to bring it to the expected mileage. The dealers took about 30 seconds to nip outside and reset the indicator.
Did they connect the car to a computer to do that?
if not then you're now on a fixed interval and your next service indication will be in 10000 miles.
