Retro Fit Cruise on a 2007 Octavia?
Just bought an 07 Octavia Ambiente. Very pleased with my purchase, though it doesn't have cruise.
I saw a thread on retro fitting cruise to 2010 onwards cars, though can't see anything for older cars.
Is it possible to retro fit cruise onto an 07 Ambiente, or is it just not viable?
Really chuffed with the car - it's cosmetically challenged but drives great. Am hoping to get many miles out of it. This is my third Skoda having had two Superbs before (including an Edition 100).
very easy on a 2007 car
you just need the stalk, providing your steering controller supports it
Thanks for that Eddie - I'll look into getting it done. If my steering controller doesn't support it - can that be changed to one that does, or is it not as easy as that?
that can be changed, they are very cheap now
Hi, I’m new to thIs place, I had a 2008 focus pior that had no cause control so I got the right steering wheel an airbag, no luck , found it needed coding in the ecu, did it was the best thing I ever did, forward on a few years, I’ve just bought an Octavia mk2 2.0 fsi, love the car so much but. No Cruise Contol, I found a used stalk to fit on eBay £15, I’ve looked on here a bit an it can need programming ? I’m just going to put the stalk on see if it works an then go further if I need too !( I have a odb cable but will be looking for software ? Is there a home brews?like the focuses ?
it will need coding in the steering module and engine
you will need someone with either vcds, vcp or odis
So there’s no program you can download for the Octavia that’ll do that? Looks like I’ll have to go to a vag specialist then 😞
 Edited out would this work?
Edited by Acecollie
I've got this on the to do list, albeit quite far down. I think I'll get my local independent VAG specialist to do it. The only thing is that they don't fit customer supplied parts, so I'll pay dealer or TPS prices on the parts.
Kirkynut
Kirkynut
I go down to London from time to time, I could fit it for you
I've done loads of Cruise retrofits
That's kind of you but I'm a good distance from London. Thank you though.
Kirkynut
Kirkynut
southend is not that far from the A12/m25 junction
@kirkynut I'd jump at that opportunity as Eddie is the 'go-to' person with regards to all things retrofit and modding!
Dose the stalk need a wire? Some adds show a wire too , but from what I can find a genuine arm fitted an switched on in the ecu will work no extra wire?
cars that need a wire would have been built in 2005
Mines a 55 plate lol 2.0 fsi
I'll look at it when I'm in a position to get it done as time and funds allows both are in short supply at the moment!
Thanks to you both!
Kirkynut
Do you mean a mk1 or mk2 early
early mk2
early mk2
So might be mine?
1 minute ago, Acecollie said:
So might be mine?
possibly, you should have a look for a black and white wire pin 13
if your cars vin is a 2006 model year you shouldn't need it
I’ll get my vin tomorrow I don’t know where that wire will be  I have some one local on here who’s willing to activate it in the menu for me too! Very nice people in this group
Edited by Acecollie
I had a chap travel from Belgium to Worcester for me to fit cruise control, getting to Eddie should be no problem lol
Just need to do the timing belt an water pump an cars golden with crude control, it’s a lovely car but still doing small jobs to make it as good as I can
Your not far I’m in Bristol
