it it gonna help with lowering?????
hi
like i mentioned when im driving too fast sometimes the back is like crazy,not stable.
if i lover my car like 20mm with the eibachs or weitec do you think it makes difference?
will it be better?
thanks a lot for help
My car's only ever oversteered (in the wet) since i fitted Eibach on my Fabia.
It all comes down to the tyres most of the time though. e.g..Maybe they're to worn, not bedded in(new), too cold, odd brands on each side, or low tyre pressures.
Check these first. But mine does look better with Eibachs on, and the rides not much worse either ;)
It all comes down to the tyres most of the time though. e.g..Maybe they're to worn' date=' not bedded in(new), too cold, odd brands on each side, or low tyre pressures.
Check these first. But mine does look better with Eibachs on, and the rides not much worse either ;)[/quote']
do u wear eibachs?do you feel any difference ?is it better./
i have 215/40R17 brand new good year excelance maybe 1000km on them.what do you think should be the pressure in these tyres?
thanks
I think it handles allot better with these spring (Eibach, other brands aren't as good.IMOH) As long as i remember to slow down on wet round-abouts:rofl:
As for tyre pressures, i think 32psi on the front, and 34psi on the back, though this link my help you abit better, as different people use diffent pressures all the time.http://www.briskoda.co.uk/forums/fabia/furby-vrs-tyre-pressures/18430/#post229126
Have fun, drive safe:thumbup: :D
