Wing mirrors changing angle
Hi
when I change the angle on my left wing mirror for parking, the right mirror angles down with it, same goes when I bring it back up again (I hope that this is making sense). when I reangle the right mirror the left mirror stays put
what is going on?
Go into Car settings on the Radio and under Mirror ( think that  it ) and untick the box which says " sync Mirrors "
Each mirror will then work on there own for adjustment
Edited by Auric Goldfinger
It's called synchronous mirror adjustment. The idea behind is if someone else is driving your car he/she only needs to adjust the driver side mirror and the other mirror adjusts itself.
If you don't like this feature, you can turn it off in the infotainment menu like me. :)
Isn't it the wrong way around for a RHD car, which is presumably what Mee has in Gloucestershire? The description sounds correct for a LHD car.
