Broken window switch?
Had a bunch of cronies in the car the other day, one in the rear passenger seat popped the window down for a bit... then 10 minutes later looked a bit worried and told me the window wouldn't go up. Tried the drivers side control and worked a treat, so guessing the switch is faulty. Anyone else had this before? It's under warranty until Jan so will ask my local dealer to take a look when its in for its MOT soon, nobody has operated that window via the door switch before so most likely was like it when I picked it up.
Only a cheap part if warranty doesn’t sort it.
Yeah certainly worse problems to have 😎 I have a bad history with trim, think taking the a pillar trim off for my dash cam is the first time I've removed a panel on any car without breaking a clip lol glad they used metal ones
Should just be a warranty job..... When I got my Superb there turned out to be an issue with one of the rollers/buttons on the steering wheel a couple of months after purchase and it was replaced under the approved used warranty.
Edited by WaveyDavey
