Psychoward666´s Magic
Here is my Skoda Felicia Magic 1.3MPI with power steering.
I bought her (yes, my Felicia is she) because I wanted car in the UK and I had many Felicias before in Czech Republic.
She cost me £350, body was in very good condition, minimum rust, but the rest was not good. Locks didn´t work, I had to changed and electric windows don´t work, but I will repair soon.
I had to changed battery, because my alternator destroyed it. Also I had to changed alternator voltage regulator and engine control unit. I changed oil, all filters, spark plugs, wipers, temperature sensor, thermostat and exhaust gaskets.
Now I ordered many parts from Czech Republic and I want change timing chain and suspension before I will go to MOT (end of September).
Than I want buy some new wheels (BBS R14-R15) and tyres and lower springs, repair front electric windows and make rear electric windows, install electric mirrors (I can´t find handle with switch for UK Felicia).
And next year I want to go on trip around UK, especially Scotland.
Here is some photos
Today i changed front and rear emblems, I used from Fabia III.
@PsychoWard666  Well, it looks cherry, but I suspect that any remaining electrical faults you have are hangovers from the failed regulator overcharging
3 hours ago, KenONeill said:
@KenONeill No, all electric works fine, window's motors works, but the plastic mechanisms are broken. I ordered sets for repair.
Yesterday I received package from my friend with electric front windows mechanisms. I want use these mechanisms to rear windows and steel pieces to repair front, which previous owner destroyed 😕
Today I dismantled these mechanisms and tomorrow I will prepare wiring and on the weekend I want finish rear windows. For front I need repair sets which I ordered yesterday.
Nice. Where did you order the repair kits for the front electric windows from? I have a set of front doors from a Magic which I want to rob the electric window mechanism from for my Caddy.
Today I prepared wiring for rear electric windows.
First I dismantled interior
Wiring for central locking and electric windows for front doors
Door´s wiring for rear windows only
Rear windows wiring in the door
Connector for rear windows
Interior wiring for rear windows
Up - drilled front electric window mechanism
Down - cutted manual rear window mechanism
Need to be glued, but I forget buy glue 😕
I will be continue tomorrow.
Today I finished rear electric windows.
Here is mechanism in door
And with door card
And I changed wing indicators for white and wheel caps with one with new Skoda logo. I also changed front wipers.
Yesterday I finished windows switches.
And here is video of first test
<iframe width="1903" height="719" src="https://www.youtube.com/embed/SVtTcbzCBz0" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
The link for video is not working, here is right one (can I edit previous post?)
Not now; you have a window of maybe 2 hours from time of posting to edit a post.
@KenONeill Ok, thank you.
Yesterday I started timing belt change. After work I don´t have much time, I think that I will finish on Saturday.
Here is video, car has only 68000 miles! And the chain is in very bad condition.
1) No problem; it's far from obvious that the ability to edit a post times out until it happens to you.
2) I'm remembering correctly; there's no tensioner on the timing chain? If so, then it can become slack enough to get noisy in half that mileage.
@KenONeill No, there is no tensioner.
Today I put new timing chain and gears on car, it is much better
Finally I finished timing chain change, put new oil in and now it is much better
Before change
After change
Today I finished repair window mechanisms.
Driver´s window mechanism
Passanger´s cut window mechanism
Repaired
And video of all four windows
  • 2 months later...
New front brake discs, pads, hoses and pipes. Yellow paint on brake calipers
New rear brake shoes, cylinders, hoses and pipes
Yellow paint on brake drums
Edited by PsychoWard666
I'm liking the name of the tyre brand. " Lucky land "
Nice looking Motor, our first ever Skoda was a V reg ( 1999 plate ) Felicia Pacific 1.3, bought it new for £8250
But those tyres are totally craps....I bought this car with those tyres, but at this moment I have three different brands on the car. I want buy new tyres before I will go to the MOT.
What sort of paint? Normal "body paint" will cook and burn off at the temperatures brakes can reach.
