Moaning on full lock.
Hi to All
The Fabia has started a slight moaning sound when on full lock either side. It started off very quiet and very occasional and I thought it was a brake pad resting against the disc as the car turned, however, tonight I have noticed the noise is becoming more prominent. It is a kind of low moaning noise.
Thoughts on causes? Dont think it is wheel bearings (I had these checked out at service when the noise was less noticable). Engine mount problem perhaps?
Chris
Definitely not just the power steering system whining away? Something else is it?
Hi Jason
It sounds quite different from the PAS pump. The noise is a low frequency moan as opposed to the motor sound of the PAS pump. Secondly, it seems to only happen when the clutch is up in 1st. If I trigger the noise, then cutch down but keep the engine running at the same speed, the noise stops immediately. Also, trying it a bit more, it happens a little more prominently a quarter turn before full lock.
Lastly, only happens under gentle acceleration and not under engine braking. All points to engine mounting to me. Any known issues?
Chris
Hi Jason
It sounds quite different from the PAS pump. The noise is a low frequency moan as opposed to the motor sound of the PAS pump. Secondly' date=' it seems to only happen when the clutch is up in 1st. If I trigger the noise, then cutch down but keep the engine running at the same speed, the noise stops immediately. Also, trying it a bit more, it happens a little more prominently a quarter turn before full lock.
Chris[/quote']
hhmmmmm... I'll listen carefully when doing TIR's today, and let you know if I have anything similar.........
Hi Sharky
It occurs at a bit higher speed than that. Around 1300rpm in 1st with clutch fully up.
Chris
Hi Sharky
Chris
ok I'll try... (was about to report quiet TIR's ;) )
