DPF Differential Pressure Sensor P2456
Anyone knows how to do a proper calibration+force regeneration ?
I did some research on the web but i am not sure what’s the best way.
I’ve finished the repair work and did the recalibration using the above method for UDS. After a couple of minutes the car started a regeneration and everything went good.
Let’s if anything happens soon
Another failed dpf sensor here on a 2 Yr old diesel vrs octy. Dealer replacement was £120 and resolved fully.
Mine melted yesterday on me.
I'll get the new sensor tomorrow and go from there.
I had a loss of power the last 30-40 miles home. Did anyone else experience this? Hoping it will be OK with new sensor and regen?
Hi Matty,
The power loss is due to the senzor error. Should be ok after replacement. I recomend to recalibrate it before starting the car.
Hi Roby, thankyou for your reply.
I fitted the new sensor today, I used Odis diagnostic, it didn't give me an option anywhere to do basic settings.
The car drives great again though, full power back and feels smoother.
I checked the dpf Ash load whilst I was plugged in, 36 grams of Ash, allowed 80 so should see me through till around 250,000 miles 😁
Thanks for your help! X
hi guys... i have a Golf 7 2.0 CRLB 150 cp.   213.345 km.
After I changed the belt about 1 week look this happened.... DPF senzor is molten..
Does anyone know if DPF Filetr will have to be replaced ?? or i replaced only DPF Senzor  ???  Please
Hellow again Guys.
I changed sensors in the dealership and everything is ok !   Good thing it wasn't the DPF...
Hello.
I have also had the same problem with the pressure sensors when changing the timing belt and the mechanic told me that he had not touched anything in the exhaust system. He tells me that the only electronic thing that he has touched so that the car can detect that the belt has been changed is the solenoid valve that is mounted on the cooling pump. In my case, an original pump was not mounted again and a Dolz brand was installed. I don't know if you know what brand of pump you mounted to be able to evaluate this failure. We could each put some data that can make us because this error appears.
Greetings
Hello again
Sorry about this type of writing bat I´m new and don´tknow how to change it.
Hi
I've just had a cambelt change on my 2016 Superb 2.0 diesel SEL and the engine warning light came on. OBD11 showed P2456 code which led me to this thread, and lucky I did! DPS has just started to melt.
Will replace them both asap.
Thanks All
Hi guys
Just wanted to share my experience with Exhaust Pressure Sensor on my Superb MK3. Recently poped out on my dash engine light. Went to local garage and free of charge was diagnosed with fault in 1 of my 2 sensors. As a regular customer (10 years) was offered replacement of both sensors with labour and overal price £300. Pretty shocking price. GSF Bosch £60 ish but today I decided to visit skoda service part shop. Brand new for £82 with discount. Garage said job should last no more 2 hours. So recap - to exchange the sensor took me 4 min!!!! No VCDS no diagnostic. Just took car for 5min driving still with light on my dash. Got cig and coffee for 15 min, returned back and no fault no light on my dash. Saved 220 and couple of hours without the car. Here is my spare part for others. Old one is B series new one D serie.
Just wanted to share my experience. Cheers
Hello friend!
I would like to try replacemet G450 sensors for new and make adaptions, i try this tutorial:
UDS Protocol (G450) procedure
Key ON, Engine OFF
[Basic Settings]
Select Adaptation of diff. pressure sensor particulate filter
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Resetting of learned values of difference pressure sensor
[Done, Go Back]
BUT i dont see in basic setting  Adaptation of diff. pressure sensor particulate filter and Resetting of learned values of difference pressure sensor.
Abit late to the party but it seems when a Campbeltown is changed they rmeovee the metal pipes and iv had gloss of power etc last few days and low and behold one of the dpf garages starlight away asked what I had done and the pipe was snapped off the sensorlucky i didn't burn my car most people dont check the sensor after a Campbelt replacement
On 19/09/2019 at 22:01, micro said:
Does it have to be removed as part of the job, and maybe the hose clamps are not tight enough after re-use, allowing hot exhaust gas to bypass the sensor?
They get moved when taking the housing off for timing belt
I've recently had a water pump & timing belt change.
Had to do a trip about 400 miles -- only just been able to check the workmanship!
They broke the old sensor (which they'd told me about) -- nothing a bit of araldite couldn't fix, but -- had to have a new one.
Problem is they seem to have fitted a new tube as well, which I don't think is "up to spec". It's thin rubber, very flexible, so much so that it's folded into a 90 degree bend (which probably still transmits the pressure, but isn't ideal) and also split open at the connector -- which probably doesn't transmit the pressure.
In the light of the risk of melting when it's not air-tight -- I'll not be driving it like this!
Useful to know only one connection is normal -- I was definitely sceptical about seeing two connectors on the new sensor.
(photo to follow ...)
Finally managed to transfer photo from my phone ...
Not only -- but also ...
The metal pipe that the bent rubber pipe attaches to the sensor, is a large > shape with the point having a mounting tab that should be bolted to the timing cover?
Can anyone tell me the bolt size and length needed, as mine is nowhere to be seen, and the whole thing flaps about. No prizes for guessing what it does when the engine is revving.
