Help with parts numbers...
Can anyone help me, I’ve tried looking on the 7zap.com website, and can’t find the pictures I need.
im after part numbers for oil pressure sensor (and potentially rubber “o” ring if on there), and the screws that hold the plastic casing behind the steering wheel together.
1.4 petrol mpi Aqw engine code
  • Sponsor
So last of four rows of item 2, and second of the two rows of the item 6, I believe, for the o-ring. Not at all clear from the diagram, but I seem to remember the thread on the MPI sensor is bigger diameter than the other engines, therefore would need a bigger o-ring.  Ah yeah, it says in the 'note' column M16 for the AQW one.
Edited by Wino
Thank you
